Like Tree485Likes
Yokomo YZ-2
    Hide Wikipost
Old 11-11-2021, 01:35 AM   -   Wikipost
R/C Tech ForumsThread Wiki: Yokomo YZ-2
Last edit by: lexusbest
Welcome to the YZ2 Wiki!
Features for the lastest specification YZ-2DTM3.1
  • Long specification for dirt Main chassis Inheriting the chassis cut of dirt specification, it is longer with the same wheelbase as CAL3.
  • Aluminum front suspension mount.
  • Z2-DTM2B F2 body.
  • JConcepts ASTRO High Clearance 7inch Wing.
Features for the lastest specification YZ-2CAL3.1
  • Long specification main chassis for carpets. Long wheelbase that enables even higher speeds.
  • Steel front suspension mount.
  • Z2-DTMBL S2 Lightweight body.
  • Z2-CAL2W LMR Wing.
Common features for the lastest specification YZ-2DTM3.1 / YZ-2CAL3.1
  • The conventional position and the position of the suspension arm pin 1 mm higher can be selected on the front and back of the front suspension mount.
  • Bulkhead integrated side plate with increased rigidity.
  • The kingpin position has been changed with the new steering hub carrier, the axle position has been lengthened by 1 mm, and a steering stopper has also been added.
  • Battery holder that is easy to adjust according to the height of the battery.
  • Separate the rear mount base and upper arm holder to increase the flex around the rear and improve traction.
  • Z2-018-5 5-hole shock mounting specification Rear shock tower.
  • S4-S1S 3.0mm shaft specification front shock.
  • S4-S1M 3.0mm shaft specification rear short shock.
  • S4-008R5B L5 / LD Rear suspension arm (Φ3.5 pin).
  • Z2-01069 Rear universal shaft (69mm bone).
Setup Sheets can be found here
DT CA DTM parts comparison
YZ2T Tranny Conversion List
YOKZ2-300RFT
YOKZ2-302CT
YOKZ2-302T
YOKZ2-304T
YOKZ2-503I
YOKZ2-0023
CAL3 manual
DTM3 manual
Print Wikipost
Old 12-11-2014, 12:06 PM
Racing4Evo's Avatar
Default Yokomo YZ-2
Yokomo is introducing the all-new YZ-2, a state-of-the-art 1/10th-scale EP 2WD offroad competition mid-motor chassis kit, engineered from the ground-up for today’s racing environment and designed to deliver leading-edge developments to offroad enthusiasts, all while offering a luxurious feel by featuring black-anodized aluminum parts with chamfered edges for select components.
In recent days, offroad racing has seen a shift toward high-grip surfaces; use of artificial turf, carpet and even high-grip dirt has become more and more prevalent. Last year’s World Championships was held on a dirt track where the surface was covered with sugar water to increase the grip.
With these developments in the offroad racing scene, the YZ-2 was designed from the ground-up to perform its best in today’s high-speed, high-grip race tracks.
By employing a super-low center-of-gravity motor mount and gearbox, the YZ-2 has realized an unprecedented weight balance never seen before in offroad racing cars, resulting in dramatically reduction of traction rolls on high- grip surfaces, and improved overall stability of the car.
An innovative steering design where the wiper swing action is directed toward the rear of the car affords a more direct steering response compared to conventional designs. The hard-coated, low-friction anodized aluminum cylinders leads to smoother shock absorbing movements which allows better driving characteristics.
Also, quick alignment adjustments can be made without the need of optional parts by replacing the bushings of the front hub carrier and rear suspension mounts, a quality that can be an advantage in adapting quickly to various track conditions.
Yokomo YZ-2 Wiki
YZ-2 INSTRUCTION MANUAL
http://teamyokomo.com/download/manua..._201412_v1.pdf
YZ-2 BLANK SETUP SHEET
http://teamyokomo.com/download/setup...t_blank_v1.pdf
YZ-2 FACTORY OPTION PARTS
...Pending Revision
YOKOMO X SHOCK ALUMINUM SHOCK CAP [B2-S812A]
*Need 2 sets to complete.
Yokomo YZ-2 Titanium Screw Kit (96 Screws) [Z2-TSS]
Yokomo YZ-2/B-Max2MR Ball Diff Assembly [B2-500MR]
*Includes heavy duty Tungsten Carbide diff balls
YZ-2 TITANIUM TURNBUCKLE SET [Z2-TBS]
* ALL TURNBUCKLES ARE 52MM IN LENGTH
ALUMINUM WING PLATE SET (Black)[B7-110]
YOKOMO 4MM SERRATED FLANGED WHEEL NUT [ZC-N4FL]
YOKOMO STEEL FRONT LOWER SUSPENSION MOUNT (45.8g)[B2-300FLS]
YOKOMO 30° FRONT LOWER SUSPENSION MOUNT [Z2-300FL5]
YOKOMO FRONT SUSPENSION ARM (GULL TYPE) [Z2-008FG]
*Requires gull type front shock tower [YOKZ2-017G]
YOKOMO ALUMINUM REAR HUB CARRIER 0° [Z2-415R00]
YOKOMO GRAPHITE IDLER SHAFT [B2-303IG]
YOKOMO YZ-2 Lightweight Body [Z2-101L]
YZ-2 TIPS AND TRICKS
...Pending Revision
*Some users are encountering driveshafts popping out under full up travel. This can be fixed with B-Max 2 MR REAR UNI. BONE [YOKB2-010RB] x2 needed
*If you run on a low traction surface it is strongly advised you mount rear shocks behind the arm.
*Stock pistons are horrible and should be changed immediately before build. Popular choice is Yokomo 2 Hole/1.6mm Flat Piston [YOKBM-S162]
*Associated RC10B5M Battery Foam [ASC91536] can be used to better fine tune battery position
*Schelle Racing B5 Aluminum Caster Block Bushing Set (8) [SHL1087]
Allows additional fine tuning of spindle height
* Associated B4 48Pitch Spur Gears and Slipper Pads are easily accessible direct replacements.
YZ-2 & B-Max2 MR CROSS COMPATIBLE PARTS
...Pending Revision
FREQUENTLY ASKED QUESTIONS
...Pending Revision
Q: What are the major changes from the old car(B-Max 2MR)?
A:
-NEW Wider Stiffer Aluminum chassis
-NEW Gearbox and motor mount lower and more forward (gear cover eliminated)
-NEW flat front arms compared to the old gull wing design
-NEW rear arm design is about 1.5mm shorter
-NEW Carbon Fiber Shock Towers
-NEW Adjustable Caster blocks 0°, 2.5°, 5°
-NEW Shock body, bottom cartridge seal and shock shaft.
Q: Can this be converted to rear motor?
A: No, unlike the B-Max2MR, the YZ-2 is dedicated a mid motor buggy.
Q: Does it come with a ball or gear diff?
A: Gear Diff
Q: Is there anything I should probably purchase along with the kit?
A: Different pistons such as [YOKBM-S162].
Q: Will my parts from the B-Max2MR work on this car?
A: Some parts carry over from the B-Max2MR but not very many. A lot of parts have been revised and improved on the YZ-2.
Q: What kind of wheels are compatible?
A: 12mm hex wheels; All wheels that are compatible with Associated B5.
Q: What other kind of springs are compatible?
A: Associated B5 springs, Kyosho RB6 Springs.
Q: What kind battery can I use?
A: Saddle Pack; Shorty; Square
http://teamyokomo.com/news/order_she...1210_b_yz2.pdf
http://www.redrc.net/2014/12/yokomo-...tor-buggy-kit/
Attached Thumbnails Yokomo YZ-2-yz2.jpg   Yokomo YZ-2-yz2-2.jpg   Yokomo YZ-2-yz2-3.jpg   Yokomo YZ-2-yz2-1.jpg
Racing4Evo is offline
Old 12-11-2014, 12:13 PM
ThePanda's Avatar
Trader Rating: 68 (100%+)
Nice! That is a really flat transmission.
ThePanda is offline
Old 12-11-2014, 12:28 PM
skeasor's Avatar
I really do want to get a Yokomo one of these days. That looks pretty nice.
However, Price: 46,200 JPY (retail, tax not included) seems pretty high for an RC car...wait, that's not USD
skeasor is offline
Old 12-11-2014, 12:41 PM
WillS's Avatar
Trader Rating: 32 (100%+)
With the way Naoto and Lee run V3 on carpet and astroturf, this car may just put them further ahead of the field. Will this car mean Yokomo domination at the worlds??? Only time will tell...
WillS is offline
Old 12-11-2014, 01:03 PM
Trader Rating: 42 (100%+)
Nice looking buggy!
Nexus is offline
Old 12-11-2014, 01:09 PM
Trader Rating: 13 (100%+)
Amain has is available for preorder at $350.
CTRJ is offline
Old 12-11-2014, 01:17 PM
skeasor's Avatar
I hope you know I was joking! haha
Yea, I really like the motor mount on this thing too!
skeasor is offline
Old 12-11-2014, 01:33 PM
Dan
Dan's Avatar
Trader Rating: 75 (100%+)
Is it 3 or 4 gear tranny?
Dan is offline
Old 12-11-2014, 01:37 PM
WillS's Avatar
4gear
WillS is offline
4 gear. You can see the two idler shaft bearing bosses in the right hand pictures.
otter is offline
Old 12-11-2014, 05:23 PM
chonchachencho's Avatar
This is what the b5m should have looked like! Eeeeee
chonchachencho is offline
Old 12-11-2014, 07:15 PM
rcman182006's Avatar
Trader Rating: 15 (100%+)
Subscribed and ready!
rcman182006 is offline
Old 12-11-2014, 10:03 PM
gticlay's Avatar
Trader Rating: 14 (100%+)
Very, very nice.
gticlay is offline
Old 12-11-2014, 10:24 PM
STLNLST's Avatar
Got mine pre ordered.
STLNLST is offline
Old 12-11-2014, 11:06 PM
wstuart's Avatar
Trader Rating: 117 (98%+)
Any idea on the weight. I'm a stock racing b5m light weight junkie, but if this thing drives as good as it looks I might need to order one.
wstuart is offline
